Hello,
i just ordered now a SR-009. I have here for my Lambdas a SRM-T1S amp with new tubes and new caps. Is this amp good enought with the SR-009 or must i buy a other stax amp?
I had serveral stax amps in the past (like 006t, T1, SRM1MK2, SRM-323II/S) but the T1S is for me the best stax amp for the Lambda models and i will doesnt sell it
Thanks!
I would say at a bare minimum for these truly outstanding headphones, a KGSS would be what I'd recommend. I previously owned the SRM727II and found them slower and a bit too syrupy with that amp. As well, I certainly wasn't a fan of the LL MK1 either. If you can snag KGSSHV then jump on it ASAP! Of the ones you've listed, the SRM-323II. For tube options, the BHSE or mighty T-2 (if you can find / build one).
