Hi all
here's my attempt to build a slimline amp.
I originally wanted to build a Cmoy amp but here in the UK its almost impossible to get the op amps.
I could have brought one from Ebay but where's the fun in pre built. I wanted to build my own.
So searching around I found a stereo amp based on the TDA2822 chip.
specs :-
TDA2822 stereo amp (complete amp kit from Quasar Electronics(
Case, LED, knob from Maplin electronics
power supply 3.6volt ni-cad rechargeable, 330ma
Output impedance 4 - 32 Ohm
Freq. response ~ 30 Hz to 100 kHz, 16 ohm
S/N ratio > 80 dB
I have not measured the power output yet but it is really loud
The biggest problem with building this amp was that the internal case size is 11mm.
The circuit hight is 10mm (without solder connections) so everything had to be shoe horned in.
I also had to insulate the circuit board as well from the ali case.
Also the volume control is actually 16mm diameter so I made a small cut out in the bottom of the case below the volume control to enable the volume to fit the case.
The sound quality is very good (to my ears at least) and is slightly bright on the higher frequencies but then this compliments my Schenniser IEM's very well.
The sockets on the back are power on/off, and a USB pass through using two USB sockets.
This is also how the battery is charged up.
This allows me to plug my mp3 player into the back of the amp and then use one USB lead to charge my mp3 player and charge the amp.
The charge current is about 25ma for the 330ma battery, so about 10 hours of charge time is needed.
the amp lasts about 6 hours of listening before charging is needed.
Overall this is the smallest amp that I have made (without going to surface mount building) and works very well.
Total cost was around £40 including the battery and all leads.
I would only recommend the brave try to build something this small.
