Koukol
- Feb 2, 2014
Thanks, Pal.
Can you elaborate a little?
I couldn't find the FLAC option in the Compression Options.
I confess know little about this program as I just put in the disc and click copy uncompressed in the Action folder.
What options should I choose to make the best copies of my CDs for the Pono?
Okay, it doesn't make it obvious. Having had it installed for a while, I forgot about getting the options right.
Under Compression Options, select 'User defined Encoder' from the dropdown box. In the little box below that, you should have ".flac" (don't include the quote marks).
Below that, there's a 'Program Path' box and a 'Browse' button. On my laptop, the path is C:\Program Files (x86)\Exact Audio Copy\FLAC\FLAC.EXE This may autofill, or it may not.
Find that, and you should be okay. Options below that include 'Quality' (pick 'High'), 'Delete WAV after Compression' (select if not already selected) and some other stuff, which I left as default when I installed (as far as I can remember).
Under compression options I only get the choices..."waveform" "external compression" "comment" & "IDtag"
could we have different versions?
btw~Is your name a tribute to Joey Ramone?
