I had an idea, and it worked well. I am a ZMF fan and have many of thei headphones, and have also used ZMF pads to transform - both in convenience, and in sound - many other headphones.
I took some measurements of the SEM1 and realized that those could fit.
Taking off the original pads, as everyone adivsed, took 30 seconds. A gentle pull on that final part that's adhered, and it's cleanly off.
I took one of the extra ZMF pads I had available - the Auteur Lambskin Perforated pads - and they fit perfectly. It took me 10 seconds per cup to put them on.
This means that any of the ZMF pads done for their own core headphones - the Universe, Auteur, BE2 (in leather, sueded, hybrid, or protein) - will all fit the SEM1. Which means an endless supply of perfectly fitting, high quality, comfortable, and sonically varied pads. I have many of them at home, and when I come around to it, I'll pad roll a bit (as I have on ZMF's on headphones).
I've used their perforated pads, as ZMF advises to use them for their open-backed headphones and use the solids pads for their closed backs. Replacing the original SEM1 solid pad with the Auteur perforated pad immediately open up the sound stage, and releases some of the excess bleed of bass to mids. The specific pads I'm referencing is known to be a bit more bassy vs. the others, and indeed here it retains the bass very well. It may be, by chance, the better one for this headphone any event.
As a bonus, genuine leather and quality that will last...
Last, I used the advice one of you gave further up, and just took an adhesive tap and applied it repeatedly to the top part of hte flaking headband. In a couple of minute all the flakes came off, and it's now like a brand-new suede headband. No replacing required. Looks like new. The bottom sueded as originally intended, and the top now matches. zero of the original leatherette remaining.
So this is now a simply modded, durable, and better sounding headphone.
Hope some of you may find this helpul!
