ozyx
- Nov 30, 2013
I've decided to buy either the X1 or the X2 but I am not sure which and when.
As was mentioned earlier Amazon.it has the X1 for €183 and the X2 for €229 (not in stock)
Should I wait for the X2 to become more available to read more reviews of it and hope that at that point the X1 and/or X2 will be cheaper?
Or should I buy the X1 now, €183 seems like a good price and it seems that the X2 will replace the X1, so it is likely that the X1 will stop being available soon.
Or maybe I should order the X2 now, locking that €229 price? I am thinking that they might jump back to €299 once they are in stock. Then again if the X2 are just "tweaked X1", then soon they should be available at X1 prices.
If the X2 doesn't have any issues and it sounds at least as good as the X1, then it seems that those extra €43 might worth it, as you get a better cable, replaceable earcups and apparently better fit for bigger heads. But the reviews of the X2 are extremely limited right now so would I be taking a risk ordering them now?
