Tubebo:
I'm still pondering the merits of the Perreaux versus the SinglePower PPX3. In an ideal world, I'd just go down to my local UberStore and audition them both. Unfortunately, I'm stuck trying to parse written comments from different users and translate that into what my own ears will ultimately hear … an exercise in fantasy!
I’ll be using whichever amp I choose to drive HD600s and like a “tubey” sound. At a recent HeadFi meet here in Ottawa, I had a chance to listen to my Senns driven by both a Headroom Max and an MG Head MkII … as great as the Max sounded, I preferred the much less expensive tube amp. With a handle like “Tubebo” I’m sure you can understand where I’m coming from.
I asked Mikhail about using the PPX3 with Senns and here’s his reply:
“We voice all of our amps with the CD3000, HD600, and RS-1.
The HD600 does very well with the MPX3 and the Supra. The
PPX3 will do fine as well, but we recommend at least an MPX3
for maximum performance. We have many customers who listen
to the MPX3 and Supra with HD600 and HD650.”
From all reports, the PPX3 is a terrific tube amp and if I weren’t using it with HD600s my decision would be clear. Mikhail certainly didn’t rule out using the Senns with the PPX3 however the phrase: “The PPX3 will do fine as well, but we recommend at least an MPX3 for maximum performance.” raises questions. Perhaps it still sounds fabulous but just a tad less fabulous than with an MPX3. His ears are probably far more discerning than mine.
The obvious solution is for me to get an MPX3 however that’s twice the price! Since you’re a tube fanatic and HD600 owner, can you comment on your feelings regarding the Perreaux versus tube amps for driving the Senns.
Thanks
Peter
