Orpheus
- Aug 17, 2002
there are many reasons to use the preamp between your headphone amp:
1. source selection (if you got a turntable or whatever)
2. optimum signal level to your headamp (yes, a signal can be too loud OR too soft for your headamp, no matter if it has a volume knob or not)
3. balance control (if your preamp has it)
4. using an effects unit, such as a crossfeed or eq, then being able to apply the effects to all your headphone amps at a centralized location
5. and if you believe in that kind of stuff, no degradation of the signal for your speaker amps or whatever, since you won't be going through the loops of your headamp
6. basic volume control: i have three headphone amps currently, and each performs better with different levels of input signal. thus, you need a preamp to tailor the signal level to each headamp.
there's plenty more reasons too...
anyway, back to the subject, the perreaux rocks.
