VXAce
- Oct 1, 2013
Snake oil is good!
Both Clevo p775 w AUO 4K screen and Acer Predator w the same screen just appeared on market, and I already read all reviews existent on internet for both.
I was kinda asking for personal opinions and advice, maybe someone had once an experience similar to mine, or someone owns the same model and can give input.
As far as I am concerned, I can get 4K + gtx980m + i7 6700hq for 2320$, and a clevo w desktop 980 and i7-6700K would cost up to 3650, about 50% more. I highly doubt that I would really want to dive so deep, but I love to make sure that I am doing the right thing. I *think I would want the clevo, but I am way too afraid that cooling and components contacts might come off bad on my side. Also, they have GPUs on chips, thing which leaves me up with asking how exactly do you fit that component on coolers, I mean, CPU cooling can be so and so, but GPU cooling needs to be top notch, and from youtube, it seems that the person who sells it must apply thermal paste directly on gpu, and I am not sure about that.
In another order of thoughts, I think that after watching so many videos about acer predator, there is way too little data on it, like how does it feel in real life usage.
I don't know anything about computers... but you know.... http://pcpartpicker.com/p/bZr36h
Sure... because you need to have top of the line stuff to do tasks that could be done on cheaper, lighter hardware. Perhaps you really should do some research, because I can probably find about a million benchmarks on lower level hardware that will accomplish the exact same thing.
You should also google up the "placebo effect" and "studies on the effect of marketing". You might learn something.
Yeah... you have no clue.
Ummmm, yeah, you really should look up what the "placebo effect" is... I used to work with video a lot working with encoding and decoding along with some rendering on end user side (though I don't do it actively anymore)... and you have the wrong idea of what the algorithms and filters do to video. You also don't have any idea what it changes in accordance to the display and how much of an impact it can have. You must do some pretty aggressive research if you have almost no idea what you are talking about...
So I recently decided to go with just a laptop (or is it an ultrabook) in the Dell XPS 13 and space is limited. it came with 128GB however I can later upgrade it to 512GB but I want to wait until my 30 day warranty is up just to be safe everything is fine.
I had a bunch of music on my desktop but obviously I don't have enough space now. Would the best way to buy a portable drive (2 or 3tb wd passport ultra) and have a backup somewhere else and use that as music only? I'm not sure how reliable portable drives are.
Interesting notion which I didn't realise (the binning)...The drives that you will get with the external drives are typically a lower binned set. So generally they are not has high quality and not as reliable as the desktop drives. If you plan on storing your life on them, I would not recommend using a pre-built external drive, purchase a normal desktop or laptop drive and a enclosure for it and you will probably end up with a better drive than the ones in the externals. If you are just planning on putting data that you don't care much for, go for the cheaper ones, after all it is data that won't kill you if it is lost.
