- Apr 9, 2011
Need a little help. Ok so, my stuff runs fine except for one problem: Game freezes and crashes. On BF4, I'll be playing, and every 5-7 min., my game will freeze, close, ad the little blue bar will say transitioning, so I have to go into Task Manager to close it. On Insurgency, every few minutes, the game will freeze and do the skipping sound thing, and I have to Alt + Tab out and bck in to fix it, only to have it happen again in another few minutes. Apparently, Gigabyte's App Center was apparently causing BF4 to crash, and when I disabled it, it worked (yesterday) and today, it started up again.
Disable all startup programs. Enable only bare minimum services.
Disable AV, and 3rd party programs. Now try.
If it doesn't work.
Boot into a safe or Windows mode that has minimal services that will still allow program execution. Disable AV. Now Try.
Work backwardsd slowly enabling apps to find the one or one(s) that cause the issue.
Another thing could be drivers. Is it the most recent drivers? If so, when did you last update drivers. If recently, rollback to previous version.
Also, reseat your hardware. It seems you did a recent hardware change switchup. That could cause errors. Just reseat
