Planar_head
- Jul 3, 2008
Can't wait for some impressions!
Originally Posted by catachresis Sim1, if you haven't seen this, it is very good to ponder: Fostex orthodynamic headphone identification guide. |
Originally Posted by Kabeer I have been waiting months... |
Originally Posted by ericj /img/forum/go_quote.gif I wonder what the heck they mean by "No steel used for magnetic return path". |
Originally Posted by BoilermakerFan Well, the rubber cement didn't hold so I had to use double-sided tape. |
Originally Posted by BoilermakerFan On the YH-100s, does opening the vents make the bass drop off or go up? |
Originally Posted by cetoole /img/forum/go_quote.gif Holy crap, I will definitely have to check these guys out. The only gear I brought was the NAD RP18, HP-1, and HP-50A, so it will be sweet to compare my stuff with this new Audeze cans! |
Originally Posted by xsankar /img/forum/go_quote.gif I will bring a transducer separately so people can look at it. |
Originally Posted by Audeze /img/forum/go_quote.gif Kabeer, Thank you very much for posting this. We really look forward to your opinions about our headphones and meeting all of you enthusiast. |
Originally Posted by Kabeer /img/forum/go_quote.gif This is actually as important a release in headphones as the HD-800 (PS1000 is just another grado reflavouring nothing really revolutionary there). |
Originally Posted by DefectiveAudioComponent /img/forum/go_quote.gif Could we compare it to something less expensive? There is no way that I could afford anything near that price range.... I'm more happy about this release than the HD800 or PS1000 though, both because I hope that this will actually be affordable, and because I want to know how an upgraded 2009 planar magnetic could be. |
Originally Posted by sachu /img/forum/go_quote.gif I'll be sure to take lots of photos |
Originally Posted by wualta /img/forum/go_quote.gif Have you ever tried contact cement, which is basically super rubber cement? Opening the cup (ie, putting vents in it) keeps the driver from singing soprano, but lets bass backwave out unimpeded to futz with your enjoyment of life. Going halfway between sealed (=> soprano) and open (=> bass cancellation) by blocking the vents with a resistance (felt) gives you more of the bass the driver's putting out and doesn't push up the ol' f-sub-zero. |
Originally Posted by BoilermakerFan I switched to a thin synthetic black felt in the vents from the thicker white Ludoo had in there. |
Originally Posted by BoilermakerFan Added a 30mm diameter disc of micropore tape directly to the back of the driver. Left out the foam and felt, then made a 45mm diameter disc of fiber glass about 15mm thick like Tomek's egg. ...sound was better, but back to being under-damped and dark.. |
Originally Posted by BoilermakerFan I need a touch more dampening on the bass, or rather I need to get the treble up. So now the debate is whether to just completely tape off the driver, or tape off the driver and add a little wider disc of FG. |
Originally Posted by BoilermakerFan I think adding more FG would risk making the bass muddy again, correct? I may just add the cashmere disc back in behind the cheesecloth over the micropore before the FG if the complete tape doesn't work. |
Originally Posted by wualta /img/forum/go_quote.gif Yeah, you can approach sealing the cup if you use felt that's too dense, although I don't know that ludoo's felt was that much more dense than stock. Fiberglass, even the fine stuff used in closed-box speakers, isn't dense enough to make much resistance to airflow, though it's great for sopping up treble so it doesn't bounce around in the typical Yamaha enclosure, creating mischief. A circle of micropore that doesn't cover the entire back is basically a slightly-porous reflex dot. The major airflow will simply detour around it and come out the surrounding uncovered holes. R10 pads must be expensive, but it sounds like they have properties we should study. As a start, try taping the driver, but make a slice in the tape to let out the solder lug and wire for the central electrode so all the tape is snug up against the driver, no bubbles or any way for the backwave to get out except through the pores. Pop in the fiberglass as a treble sponge. I don't think adding more FG will hurt anything, though it might soak up enough backwave treble to bring the top end of the frequency response graph down noticeably. Might be handy if the full-micropore treatment overdamps a little. Sachu, take lots of pictures. Practice using your macro setting and turn on your burst mode. |
Originally Posted by fsma /img/forum/go_quote.gif Brian: You should really consider getting some bitumen to use instead of blu-tak. I found it made a world of difference when I made that switch. |
