Synthax
- Jan 11, 2013
So i dug out my sansuis tonight.
It looks like I had just stuck them into the DT-990 cups and taped them in place.
So this time I put a layer of dense black felt against the back of the cup, then a 1/4" thick disc of some soft open cell foam. The original fiber cookie is still in place.
taped them back in, and put on superlux-grade not-quite-beyer velours. along with the foam cover discs from my hd-660.
Bright isn't the word. Hot, maybe? Even harsh. There is accuracy and even bass but the mids could come forward and the treble is too much.
The lens i seem to recall from your post makes sense. I'll try that at some point. I'll also stick something more substantial than the wispy cover foam in front of the driver to try and tame the treble.
I hope You'll finally achieve best possible quality for these excellent drivers In my case drivers in this housing without bass lens (inside diameter about 40mm) was not acceptable. What I have noticed is that distance of transducer from ear, sequence of damping, density, size, and shape make key role with ortho drivers - and even one small change can absolutely spoil the sound - make it more telephone effect, or too dull, or generate some nasty peaks, depressions in frequency response and so on... Is is trial and error way what many of us now very good.
Few days ago I have reached totally eargasm with my setup. With Conducfil 3014 cable, 4mm felt bass lens at ear side, white cosmetic wool 5mm layer on back of the cup (instead of yellow original wool) and hifiman's velour pads. It sound excellent. When I have heard it first time this configuration I've told to myself - och It sound so 3D, so real, so beauty. Till now all tracks sound perfect with this configuration. The 3D soundstage is far better than LCD's... (ok the bass of LCD is still stronger and more linear but only this) And the air in the sound is impressive, still having crystal clear bass lines.
Yesterday my wife tried these headphones and she told my that she hardly started to cry as the music sounded so beautifull... Like never before on any system she have heard.
It is absolutely a kind of synergy. Non fatiguing, lifelike, rich, dense, full of air (musical plankton) and 'liquiditity' reminds me a bit sound od hi-end open baffle system, where the sound is so free in presentation and no distortions come from overdosed bass or resonances of speaker box.
With velour pads the volume pot has to be open a bot more to achieve same level of sound than with pleathers, maybe the sound is better also due to more power into it.
PS: Sorry for my mistakes in writing.
