DefectiveAudioComponent
- Jan 20, 2008
I have both. Just the color.
Have you found any nice replacement ear pads for them?
... after some listening to the RT-10, I'd say this mod is most useful if you find that the treble is ok, but that you just need to get stronger bass / deeper bass extension.
In comparison, if I instead close the baffle, then bass goes up as well, but then treble is reduced quite a bit.
What pads are those and how do you find them?
Is there any difference between Silver and Black ТДС-15?
BMF is correct, but there are also some that are tuned a bit warmer. I think the ones you see currently up that have the gold lettering with the gold circles ( both silver and black ) are the same maker ( I can't confirm) just different colour, because they have the exact same markings.
The silver ones with the gold dots are tuned higher than the other black ones I have that have white lettering and no dots ( which are darker sounding ).
BMF would have to confirm if he has two sets with gold lettering or not.
I forget how many places made them.
Is that an 890 stand ?
ericj,
In my country Superlux HD330 costs 40$, it's real bergain for mods like mine. It is not bad quality as a headphones frame. I've ordered velour pads, because stock is made of cheap pleather. Beyerdynamic and Hifiman fits OK. One important note is that Superlux headband size is a bit smaller/shorter than Beyerdynamic typical one. And if you have a big head You need to be aware. Me I did some mod and now it fits perfectly and the sides move much further than stock lengths.
What rear dampening od drivers do you use, if any ?
Welp. Here you go.
The photos don't do these justice, btw. This is the most beautiful headphone I've ever seen.
