Looks like pictures were already covered on the HA-2, so that saves me some time and effort. Haha. I've got some thoughts to share on the device, but do keep in mind anything could change between now and release (for better or worse). If I don't mention something or don't go into detail about it, there's probably a reason for it and not just something I overlooked. In particular, OPPO didn't want beta testers talking much about sound and tuning yet, as those are the aspects most likely to change by a good bit before launch. Perfectly reasonable and understandable to me. And I do want to give a big thanks to OPPO for getting me involved in this beta test! I'm always eager to try out and analyze products to provide any information and feedback I can to help the community and industry.
In terms of looks, feel, built quality, functionality, it's really great. Of course, is that really all that surprising coming from the PM-1/2? I might have thought the PM-1/2 were not quite where they needed to be with absolute or relative sound quality, despite still enjoying them, but, wow, did they excel when it came to presentation! The HA-2 is right up with there in that regard in terms of presentation. For me, I'm really most concerned about sound and functionality, but having a nice looking and high-quality feeling device doesn't hurt.
The best way I could describe the looks is classy and high quality. Feels like a nice slab of metal (aluminum?), generally soft matte metal with some shiny/polished accents around the edge, wrapped in an adhered leather cover (may be subject to change). It's roughly the size of a common smartphone with a thin case and, as such, fits and feels great in the hand.
As you know, it's a portable DAC/amp, and it can be used in whatever configuration you prefer. Want to use it as just an amp? No problem. Just use the 3.5.mm line-in jack with an existing DAC. Want to use it as just a DAC? No problem. Hook it up to whatever device you want via USB and use the line-out jack. As it happens, the line-in and line-out both share the same jack, which I think is pretty smart and handy. And, yeah, works well as an integrated, portable DAC/amp. Aside from a few expected bugs (it is a beta, after all!), it worked pretty seamlessly with the iPhone 5S and HTC One M7 I tested it with. With the supplied drivers, it worked without a hitch from my desktop and my 8" Windows 8 tablet via its micro-USB out. I do believe the device will include plenty of cables to get you started. On the beta HA-2, the standard USB port is for iOS devices, and the micro-USB port is for other devices and charging the HA-2. Not sure if that will change at all with the final product.
As I understand, you can even use the HA-2 as a backup battery to charge your devices via USB. I'm not sure what other similar devices offer this feature, but I think it's a nice touch.
You probably noticed the bass boost and gain switches in the pictures. I don't have any issues with bass boosts, as they're good for those that want the option, though it's not a feature I'll ever really use. I'm not sure if OPPO will tweak the bass boost tuning for the final product, so I don't want to speak much on how much it affects the sound.
In terms of power and ability to drive headphones, let's just say I can drive stuff like the HD650 to LOUD volumes on low gain. Plenty of power to be had from the amp.
Like I said, I don't want to get much into how the device sounds, given that's the thing most likely to change. What I will say is that I think the HA-2 sounds pretty good as just a DAC in the beta state, and this is coming from someone who usually is not crazy about Sabre-based DACs. I think there are still some gains to be had, but it is enjoyable in its current state. A promising sign, IMO. I am most curious to see how the amp section sounds when the HA-2 is finished, but you can at least rest easy knowing it will probably drive everything except the pickiest and most difficult to drive headphones. Yes, I am being vague on purpose.
If anyone wants and other specific details on the device or has any questions, let me know, and I'll do what I can to answer based on my beta experience. I think with some expected, further refinement in a few areas, it will be good and solid product worth recommending. I think it already has quite a few things going for it. Pricing remains to be known and will determine its final value.
