harpo1
- Dec 1, 2014
I'm looking at getting a balanced DAC to power my headphone collection and was wondering peoples thoughts who have a balanced cable for their PM-3s.
I am looking at the Teac UD-501-B which looks like the only balanced out are the dual 3 pin XLR. Looking at the cable needed; TRRS on headphone end, and dual 3-pin XLR female for amp end. I'm interested in this cable: http://www.doublehelixcables.com/store/index.php?main_page=product_info&products_id=1 Which doesn't have a 3-Pin female XLR. Is there an adapter I can get to connect this cable to the DAC or do I need to look elsewhere?
Or this cable: https://www.moon-audio.com/blue-dragon-cable-oppo-headphones-v3.html I don't see a "balanced" option but at the bottom of the page is states:
"The Version 3 is quieter than the Version 2 with no microphonics. It is a balanced cable geometry that can be terminated for either single ended or balanced configuration.
This cable can be configured in a variety of different ways. Please note that single ended signal connection can not be converted to balanced signal connection. As the grounds are tied in the single ended connector. Therefore, only pick this configuration if your amp has no single ended connection outputs."
What does it mean "Please note that single ended signal connection can not be converted to balanced signal connection".
Thanks for any help
I have a balanced dyson cable terminated in Trrs to rsa/alo if your interested.
PM Sent.
Is it possible for you tell me a little bit how this cable behaves in portable use? Especially microphonics? With zippers etc?
What amp will you be using? What is your current balanced set up?
Sorry, been off of head-fi for a while. Hope you still need the feedback. There is no microphonics in the cable from what I can tell, it's much quieter than the stock cable to my ears. It plays very nicely with zippers and clothing, feels great and all of that. The only problem I have with the cable is that when it gets twisted it coils up pretty hard, so you have to make sure it doesn't get twisted at all. Once I have it on and the player in my pocket though, I can leave it like that all day as I travel.
Hi here! Just a quick question : Whitch dap can be the beater fit for the pm3 ? Between the acoustic research m2, the fiio x7, or the new ibasso dx200.... ( pcm 1794 va dac sabre ) ?
Thanks you !
Pm3 holes look really big, maybe with my ears it's the depth, i don't know.
At home I only got the hd590, besides the pm3. I think they are extremely super comfortable. But holes aren't that much bigger. There is absolutely no contact to the ear.
Strange thing is, the on pm3 only hurts my right ear. I can't see any differences on my left and right ear, so I'm a little confused.
For the most part, the pm3 is comfortable. After an hour or so, I sometimes put them off for 3 minutes, and everything is quite fine. Not as ultra fine as hd590, but the difference in sq is worth it thousand times
That's a tough comparison for the PM-3 or any cans really, My old HD-590s are, to this day, still the most comfortable cans I've ever owned. Long after they died they remain my "gold standard" which all other cans are compared against. In my competitive FPS days, I would routinely wear the HD590s for as much as 9 hours without a break, and then i'd get up to go to the can or grab food and get my head yanked by the cable because I'd forgotten I even had them on. They were really that comfy. I ranked them 9.5/10 in comfort, where 10/10 is "not actually wearing anything" and 1/10 is "a screwdriver through the eardrum".
The closest I've found since then would be beyer DT-880s, which are probably a 9/10 once the pads are broken in.
My PM-3s I'd say are probably 8/10 now, maybe 8.5/10 once I give the pads more time to break in.
My Alessandro MS1 (aka Grado SR125s) are maybe 5/10.
Koss KSC-35s, as great as they sounded, were probably 3.5/10, god they hurt.
