- Apr 11, 2015
QUESTION : How do I create a playlist on the default app for Onkyo ? And whats the intuitive way to add your favorite songs into the playlist ?
I created mine this way:
Under 'Songs' navigation, click on three dots on the right of the song you want to add, select 'Replace Up Next'. It will prompt reminding that this action will reset the queue if you have existing queue, else it just playback automatically. For subsequent songs, do the same but select 'Add to Up Next'
If you want to add album, similar but need to select album first to view song list, there is option to 'Add All'.
After you have added songs/albums, go to Now Playing screen (the one with circular playback spectrum and album art as background). You will see queue icon (the one with 3 dots and 3 horizontal lines), click on it. You will see all the songs added. 'Edit queue' to remove songs or change the songs playback sequence; 'Save as playlist' which is self-explanatory.
Funny thing about 'Save as playlist' is that you could save multiple playlists with the same title. So what I did is playback saved playlist, add new songs/albums and save as new title to differentiate. Then delete the old playlist.
