They should put a USB type C in it.
Take a look at the DX120, it does.
But the dx120 has a different sound.Take a look at the DX120, it does.
Well I heard every Cowon dap and every ibasso. Most likely theres going to be a difference.None of us have heard the Plenue D2 yet, we have no idea how it sounds. We can take an educated punt though. That being said I haven't heard the DX120 either.
nobody knows. historically, people used to the interface from Sony would bang their head on a wall after using Cowon for 10mn and wondering which sick person designed that DAP. also historically, Cowon has a quieter background noise. no idea if any of that applies to those latest models but it has been true for several models over the years.This or the Sony A55 ?
it's cowon, the specs are going to be at the output of some chipset in a lab, or at best, unloaded specs. don't even dream of those numbers once you plug a low impedance IEM in it. hopefully they'll still be pretty good, but not that. I'm not sure the crosstalk figures are possible into a jack plug? and the balanced side uses a 2.5mm plug(why oh why?????????), so I would be even more amazed if it was measured at the output into any reasonable load.Seriously. The specs on this are crazy, no wonder they have been selling the older models for cheap lately, might have to return the plenue 2 and just get this instead.... Why not include the 10 band EQ and jet effect 7 though?
In balanced I guess that would be 10mW into 600 ohm. I'm not sure of the appropriate calculation to convert into how much current it could drive into a 300 ohm headphone?
depends on the actual design(because in the audiophile world "balanced" is used pretty loosely), but it's typical to double the voltage. instead of a + and - system on each channel where + is the signal and - is the common ground to both channels, you could get + and - both sending the same signal but out of phase so the resulting amplitude would be doubled in volt(or +6dB). not sure if it's exactly what's going on here, but usually that's the idea.That being said, 2 lines running 2.0 Vrms doesn't equal 4.0 Vrms....
Yeah releasing a new player in 2019 without USB C is a bummer. I currently have the D but when I upgrade I'm not sure if I should go for the D2 or the Fiio m9. The m9 only has 10 hrs of battery life which is quite low. It sucks that the D2 has less battery life than the god-like 100 hrs of the D.
