in most cases i use the mojo alone but in some cases i do add the vorzuge.....and i do believe the vorzuge pure II+ to be the best portable amp available given its size and portability...I see the new cavalli which i am sure is outstanding but it isnt as portable,i will stick with the vorzuge
Yeah, it's really nice: piccolino wire and very well made. It's from qusp here on head-fi, but it's several years old and I'm not sure he's in business any longer.
The Mojo just like the Hugo can be set as a line out. Even when done so you can adjust the signal out as this adjust the line voltage. So if the signal is to hot you can tame the output.
Yes it's just a set point. You can adjust it from there or start at 0 . The signal does not change only the voltage.
I think it's 3 volts with Mojo and 2.2 volts Hugo.
I use the line out with a Vorzuge Pure ii
Variable line out with power amps at home and Variable line out with Cavalli Liquid Carbon.
Hope your having a great time this Christmas Eve .
I am 3 boys 11, 8 and 3 weeks old.
8 year old is buying the beer
Wow! 6 months since last post in this thread! What have I've been up to?
As of a few weeks ago, my Vorzamp duo started discharging when not in use. It does this quite rapidly. It goes from full charge to empty over night, even when it's not in use
I thought it might be a battery issue, so I bought 2 spare sets of rechargeable batteries (directly from Vorzuge), but didn't solve my problem! Anyone else experiencing this?
