kkl10
- Dec 26, 2010
Alright so it seems that the M50s are just not for me. Having had them since june, i see that they dont have enough mids and too much bass for my liking even with Equ. It gets too loud that ill lose my hearing or its too low and the vocals/ detail wont come out. So i will make a preference list of what i would want from my next headphone.
music: all genres, from classical to rap to rock. I want something that can handle everything and stay pretty neutral with emphasis on mids/vocals.
Closed headphones preferred with decent soundstage. Cant have painful highs or simbliance. Minimal sound leak. Comfortable if possible. Not super long cable. $200-250 to spend.
My source: ipod touch 4g, equ app. 192-320 kbps tracks.
Thats about it. Note that this is a future endeavor when i get the money to upgrade. So not for awhile. For now i have to keep the M50s. Ive done foam mod so dont mention that but if u want, post suggestions if u find ones that might be useful for the m50 for now. Other than that post headphones that i might consider for my next purchase.
Thanks
You may want to check out the GMP 8.35D.
You should do a bit of research...
