saint.panda
My memory might be wrong but compared to the Earmax Pro and balanced Dynamight, the Aria had a bit less bass presence on all three sources (McCormack UDP-1, Dodson DA-217 MKII and a high end custom cdp). While the Aria's bass was more refined, better textured and tighter, the EMP had a stronger bass presence. This is not to say the EMP is more accurate, on the contrary, but I merely wanted to stress that depending on the headphones and especially personal preference, one might tend towards a more emphasised bass presentation. With the AKG K701 for example, which I heard on two auditions, I prefer the EMP's slightly stronger but also "wider" bass. The Dynamight on the other hand takes the Aria's bass definition and adds more punch. Again, I can only say this from memory and at that time I didn't specifically listen for bass differences but I think it was quite apparent nonetheless.
I think a source can only do so much with regards to frequency response and if you compare two upper end cd players, both with an even-handed frequency response, I doubt there will significant differences in the bass output for given frequencies. However, if somebody were to prefer his bass a tad stronger, the Aria might not be first choice. Certainly, it's also headphone-specific.
Originally Posted by kuma A bass lite with Aria? Not with any of my sources. Even the 271s outputs respectable bass with great articulation and defnition. If you have a bass problem, I suspect it's the source. Its tonal balance is leaner than my Headline, but it can produce an appropriate bass if the source is up to it. |
