The GR07 is plenty deep, it just doesn't have very thick note presentation so it sounds lightweight and 'punchy' at the low end rather than full and weighty. The FXT90 bass quantity is about the lowest I would recommend for someone used to 'consumer' sound (e.g. NE-7M) and not actively looking to take a step towards accuracy. While I do think the GR07 is slightly better from a technical standpoint - tighter, clearer, more neutral, more spacious, and a touch more detailed - there's not much of a purpose in paying extra for an earphone you may like less. That said, you used to own a Shure and unless it was an SE115 it probably wasn't as bassy as the NE-7M so you sort of know what to expect from a more accurate in-ear. The beauty of the FXT90 is ease of use, though - it's a very user-friendly earphone that's shallow-insertion and fairly forgiving of different types of tips. It's got good separation and imaging - it's no FX700, but quite close considering what it costs.
Great info - exactly the type of information I was looking for. I believe the SE315 is the model I had. I was able to get it dirt cheap through a manufacturer accommodation deal when I worked retail. It was nowhere near as bassy as the NE-7M and I enjoyed it. I also have a Bose IME2i set that was given to me as a gift - which I am not very fond of. The isolation is terrible and I find the highs too harsh for my taste.
I am certainly looking more into taking steps toward a more accurate IEM vs consumer. I also don't want buyers remorse, which I tend to get a lot. I am very easy to "upsell" myself when looking at products. My taste in music varies a lot. I will listen to classic rock, alternative, metal... but also several acoustic tracks, some techno, etc. I believe I am ready to delve into a more accurate phone so I can reap the full benefits of lossless audio tracks.
I think my concern with the FX700, which I
was looking at at one point in time before I cut my budget back a tad, was the isolation. Comfort is very important to me as I listen to music a lot while relaxing and not necessarily "on the go," but I want a phone with a great seal as well. Also while at work, I am often removing my phones and reinserting them as I do move around a bit and need to get on/off the phone a lot. I read your reviews for the FX700 and the GR07 and have to ask myself if the difference is really enough to justify double the price tag. Budget was really cut because after reading several reviews, it seemed like there were more "bang for the buck" options at a lower price point. The more I read and learn about different types of sound, transducers, etc... the more I learn the benefit of the higher end models. I begin to ask myself If I am willing to spend $340 on the FX700, is it more worthwhile to look into other 1C or even some 1B models.
The novel Ive written aside - I am willing to sacrifice a more "boomy consumer bass" for accuracy. As my collection of lossless audio files grows, it defeats to purpose to me it seems to not focus more on accuracy. I believe I just put a bit too much emphasis on bass in my original post.
I think I am going to start off with the GR07. It sounds like a great phone to ease me more into the higher end IEMs. Why do I feel like I could see this becoming an obsession?
