TigerA
- Sep 27, 2011
For the amount of bass that it has, I think the E10 has excellent clarity but in the budget segment you can't quite have it both ways. For what it's worth the E10 is reasonably quick and has decent enough dynamics so it doesn't sound bloated. If you're a vocal lover you might find it a bit too v-shaped but then again if your Resonance isn't delivering enough bass, the ProAlpha won't do it either. Have you considered jumping to the Brainwavz M2 or Xears TD-III? They are both mid-forward and bassy while retaining decent enough treble and presentation.
I'm in Europe and E10/M1/ProAlpha/TD-III (All Xears models) are in the same pricerange. M2 (€45) is even more expensive than any Xears model (€38). Since I already have 2 Xears models, the Resonance and XSR330PRO I wanted to try out a IEM from a different brand. But by reading your reviews i'm not sure I should go for other brands. Unfortunately I don't think you have tried the XSR because it's not a sound signature I like. I feel the bass it produces dominates a bit too much and the vocals are too much in the front, that even sometimes some words are just too hard to hear. I like them a bit further away. Maybe it's because of the XSR that I find the Resonance bass light. When I first got them I don't think they were THAT bass light, now whenever I use them again they are devoid of any bass :/
The M2 scored lower than the TD-III and in it's turn it scored lower than the XE200PRO. This one and N3i are your highest scoring Xears models. Shouldn't I go for one of these instead? Though the XE200PRO is sold out atm and will be available in a walnut version later on.
