wilzc
- Apr 16, 2011
The man has his life to live too you know
and how are they compared to the pl50 in vocal/mid-fwdness ?
I'm in Europe and E10/M1/ProAlpha/TD-III (All Xears models) are in the same pricerange. M2 (€45) is even more expensive than any Xears model (€38). Since I already have 2 Xears models, the Resonance and XSR330PRO I wanted to try out a IEM from a different brand. But by reading your reviews i'm not sure I should go for other brands. Unfortunately I don't think you have tried the XSR because it's not a sound signature I like. I feel the bass it produces dominates a bit too much and the vocals are too much in the front, that even sometimes some words are just too hard to hear. I like them a bit further away. Maybe it's because of the XSR that I find the Resonance bass light. When I first got them I don't think they were THAT bass light, now whenever I use them again they are devoid of any bass :/
The M2 scored lower than the TD-III and in it's turn it scored lower than the XE200PRO. This one and N3i are your highest scoring Xears models. Shouldn't I go for one of these instead? Though the XE200PRO is sold out atm and will be available in a walnut version later on.
On that note, Joker you are a legend! You have been thanked a thousand times but once more won't hurtI appreciate your efforts so much and enjoy reading your reviews very much...thanks! It was based on this thread and your portables thread that I purchased the ProAlpha and the CAL! They are both bang on the sound I like.
You may get a pair of XSR's in the post
I just wanted to add that the ECCI PR401 is now $70 at lendmeurears (has been for a couple weeks) and that I think it's a wonderful sounding and overlooked IEM
Whilst I'm here, Joker can you give me some advice. I mentioned on the Xears thread I would like to try:
Dunu Trident
Fischer Audio Eterna
Fischer Audio Genesis
Xears TD-III
Xears Resonance
HiSoundAudio Popo
Brainwavz M2
Based on myexperience with the XT2 Pro and XSR I think Xears may not be my thing. I guess I'm after something similar to the ProAlpha but with more extention either end. I don't want anything with a narrow soundstage as I'm finding the Xears. I know you will say M2, and I will get them somewhen, but I would like to try other manufacturers. I've left off Meelectronics from that list.....was looking at the SP51.
Thanks in advance.
Hey, ljokerl, (or anyone else who can answer this) do you think the GR07s would be a suitable upper-midrange upgrade from the A151's? I listen to mostly Indie/Alternative Rock, with some classical and miscellaneous stuff thrown in... Thanks for your work on this extremely helpful thread, btw...
More so... PL50 is mid-centric but still reasonably balanced overall.
The XE200PRO may not have enough bass if you find the Resonance lacking - they're pretty similar in impact. N3i might have too recessed mids if you're after vocals.. TD-III is more forward.
can't wait for your conclusion about
Sunrise Xcited
Sunrise Xcape Impressive Edition
thanks!!
Would the PL50 be the closest to the mid-range signature of the UM3X (on the cheap), or would you recommend another cheaper alternative to the UM3X?
BTW, what's in store for #200?
Do you maybe know a IEM with a similar signature to the Superlux HD-668B? That is what i'm looking for in a IEM.
Dear Joker,
I've used the Xears TDIII, XE200PRO, Xi200PRO, XSR330PRO and the XGF500PRO.
What would I notice if I got the SoundMagic E10s compared to to the Xears that I've tried? (I assume you've only used the TDIIIs and XE200PRO so it's great if you can give me a quick comparison!)
I prefer just enough, quick tight bass, more in front vocals and clarity is quite nice. Not sure how to explain my music taste better than that.
Giving you another thanks Found a pair I liked after only the second one. First I bought was the R02. Sound was fine but that memory cable annoyed me so much. Thought I could get used to getting it to stick around the ears till it "learned". Whenever I take it out of the case I have this coiled cord plugging into the laptop which is the part that really annoyed me.
So 2nd one was the A151. The cable is awesome. The angled plug threw me off though, but once I figured that out the fit was great. Although the medium tip that is usually fine for me was actually kinda painful with these. Double flange fixed that. Even with these being my first BA earphones, I can still agree with pretty much the entire review. The sound is really accurate but also not fatiguing. Granted my main headphone is the sennheiser HD558 so I'm used to accurate sound signatures. I'd have like a little more bass but I'm still happy with it. I actually like the more recessed highs since that makes these easy to listen without fatigue. For example I played Ellie Goulding's Lights album (came out this year I think so has practically no dynamic range) with the R02. With maybe 2 or 3 tracks left I started to get kinda fidgety and just wanted the album to end. Did the same with the A151 and had no problems.
At any rate, thanks for the review and saving me a lot of trial and error.
So after a couple months the upgrade bug is biting... I've currently got the Shure SE215 and am generally happy with their sound, but after having listened to them for a while I find myself wishing their clarity/detailing were better. What are some options for a step up keeping to the same form factor?
Important to note: I have a *lot* of fit issues with iems. I settled with the SE215 because it actually fits me, if maybe just a tiny smidge too big, but it does hold quite securely. Straight barrel plugs do not fit me at all.
GR07, maybe, (or Soungmagic E30 on a budget) but you seem to be after more bass than that.
I'm actually really happy with the sound signature of the Superlux HD-668B. They definitely have more bass than the Resonance. I think there's a nice balance between bass, treble and vocal clarity.
I think i'll stay around the $50-70 pricerange for now. So, the E30 are similar to the Superlux? I'm not sure i'm gonna get a good fit with those. The nozzle (is that how you call it?) is angled, just like the Resonance(?) The Resonance always fall out of my ear. But with the E30 you have to wear it over the ear (?). Never tried one of those. I actually only want a step up from the Resonance as far as bass/treble and vocal clarity goes. Cuz I have to say that my opinion about the Resonance's bass output has been clouded by the XSR330PRO, that one is just a bass monster. Even the CX300-400 sounds tame compared to them.
Any other suggestions? Thanks for your constant input. I really appreciate it.
