kantongkresek
- Apr 12, 2009
wow. this is really nice. It helped me a lot. Thank you so much
joker you are amazing!! That is the most amazing list/comparison/chart/review/knowledge ive seen!! Thank you thank you thank you!!
Btw you nailed the Nuforce Ne-6 right on the money - My casing separated from the bud
Im really disappointed by the build quality not sure what they were thinking when they designed it - the glue just does not hold up!! Why didnt that screw it or something isntead of using weak glue :/
either way im going to use super glue or something?? Think its a good idea or should i do something else??
Warranty it. Nuforce have fantastic customer service. They'll send you a replacement in no time.
Do it here: www.nuforce.com/hp/support/service.html
Please try to get hold of the silver bullet, eterna and the hippos even if just for reviews. That would really put alot of things into perspective regarding all the other earphones. Thanks alot.
WOW, what a collection of IEMs I really amazed
Thanks a lot for the reviews! Really appreciate your effort for that!
Have you heard of Superlux HD381 series, especially HD381F? To my ears they sound very good, although I don't have the extensive experience like you with IEMs So I think your opinion would be very valuable.
FYI, my mini review about Superlux HD381:
http://www.head-fi.org/forum/thread/493052/superlux-hd381-series-mini-review-comparisons#post_6653649
This is outstanding work. Takes a real dedication. Thanks for this. I'm a newb, and still learning all the sound jargon. This helps me to understand, because I can listen to IEM's I have, and compare them with your notes. Makes it come alive in detail a little more.
This is an EPIC thread. You are amazing Joker. Keep it up.
