I use the 430HA with the HD800's and the LCD-X. Each is a wonderful pairing. The GSX MK2 is also a great amp, however, I find it a bit to concise for me. I hear more music as a comprehensive experience than the GSX which, for me, seems to break things out more into component parts. as always YMMV.
I own the LCD-4 and have a 430 on order...I am assuming that if you do not like the sound of the LCD-4 you wont like it through the 430 but if you do like the sound you will indeed like it....I see no reason why the amp should be considered first rate with all other cans but not the LCD-4
Dont listen to the Lake People the Moon is where its at.
Reviews like this as well as many others including a stellar read from longbowbbs should give you an idea of what this amp is like http://www.innerfidelity.com/content/neutral-reference-headphone-amp-simaudio-moon-neo-430ha
as well as http://headphone.guru/moon-neo-series-430-had-reference-headphone-amplifier-with-optional-dsd32-bit-pcm-dac/
and watch this till the end https://www.youtube.com/watch?v=uLzXiqvfNUU your in good company beleive me.
No, you cannot upgrade the 430HA DAC to the 380D. The DAC board for the 430HA has the same DAC and surrounding circuitry as the stand alone DAC but without the higher quality independent power supplies. The 380D is another level and is priced accordingly.
Thanks. That's what I assumed. But, if you could upgrade to the 380 DAC chip and circuitry (sans power supply) that would be sick. But, that is pretty greedy...
