rgs9200m
- May 15, 2006
So how does 380D sound? I don't see much talk about it. Thank you.
Thanks. I'm also a big fan of the AQ diamond I see in your sig and swear by it.
AQ makes great cables. I use a lot of them.
Yep, I've been using various AQ cables since 1995.
Just noting I did use the 430HA with internal DAC for the review...and pretty much all reviews since Big Sound 2015. It is my reviewing amp and will be a constant until I find a better amp for my purposes.
Currently now using the Moon Neo 430HAD with my LCD-4 and it sounds lightning fast.
This is very helpful, as I have decided on 430HA-D but not sure about better headphones to pair with it. Had been thinking of HE-1000s. My main problem is I am virtually housebound so cannot get to dealers or shows to try out possible upgrades to my HE-500s.
I may be totally off base here but I might be inclined to beleive that the HE-1000 might not scale as well as an Abyss or a LCD-4. Meaning that in order to take full advantage of all that 430HA goodness one may look at other top tier headphone offerings besides the HE-1000.
As mentioned however I may be totally off base on this one
Anyway you slice it though its a good problem to have.
