I never claimed he was lying about the connector type. Just that the review was questionable.
Monoprice Monolith M1060 and M560 Planar Headphones
- Thread starter wordfool
Kazekeil
- Jan 18, 2012
OH dam that's a nice frequency response. Csd looks a bit less nice.
As far as the connection, yes we all knew, and I was even really excited about a mmcx connection, but they obviously botched the implementation. Failure rate is already at 1% of the first 500 orders within the first day of people getting theirs.
Sorry, it was the other poster who mentioned the connector. I am typing on my phone and it's hard to track on the mobile version of the site.
Ishcabible
- Jan 19, 2009
Sweet! How noticeable is that "ortho wall" and funkiness south of 2k? I'll have a pair by the end next week to measure too.
Can I ask you to explain why this is a nice frequency response? What makes you come to that conclusion based on just looking at that graph, what's nice about it? I mean, I see the flat bass extending all the way down, but lots of otho's can do that. What else is so nice about it?
Thanks.
tgaguirre
- May 26, 2015
Calling it in between an LCD-3 and HE-1000 seemed far fetched to me and made his review questionable.
If they are really that good, that would be amazing and Ill eat my words but Im quite doubtful of it.
I've never heard an LCD-3 or HE-1000 but these do sound good and have similarities to the LCD2s which I compared them to side by side.
Maybe the connectors will be replaced in a newer version say the M1060 version 2, or they will recall all of these and change the connectors for free (not likely).
For $300 the sound of these headphones is good, although the build quality could be better and the connectors could be an issue down the road.
I heard the M560s at a meet-up once and I would say these sound much better in all respects and for sure worth $100 more sound quality wise.
Ortho walls are usually not heard. They have a direct correlation to impulse response and are affected by internal resonances and reflections. South of 2k? It's pretty damn flat minus the slight rise at 1kHz due to pad structure. I'll bet pad rolling will bring excellent results from this headphone.
Kazekeil
- Jan 18, 2012
Thanks.
My bad. Looks nice to me. As in looks like something I'd enjoy. Totally a subjective "it's nice" not objective.
m3t4lm4n222
- Feb 10, 2017
Another person who received a pair responded to me on Reddit indicating the following:
Nope, mines solid even when being pretty rough with the connector and wiggling it around with music playing. I'm not too thrilled with one of the bottom stops for the headband adjustment, looks misaligned compared to the other side. Contemplating a replacement just for that alone but now that you mentioned connector issues maybe I shouldn't.
I would read the Head-Fi thread but I don't want their impressions to influence my opinion of these.
tgaguirre
- May 26, 2015
No issues with my connectors. Make sure you match the orientation when hooking them up.
These are Chinese knock off of Audeze headphones. Not a bad thing for $300!
Measurements:
Thanks for positing those measurements. The measurements look good and I am no expert but to my untrained ears they seem like they are probably right.
They have a clean bright sound with good planar magnetic type bass. They have a fun enjoyable sound, to me its definitely not a dark or veiled sound.
They do have a depressed upper mid/treble. HD650 and my modded HE-6 are more neutral. I'm a recording engineer and appreciate a flat response so what sounds right to me might sound dry or boring to others, it's a matter of taste and perspective. This headphone with different pads can be killer though. i'll be working on mods for these.
HD650M/HE-6 modded for reference:
Netherwind
Interesting you say that they are depressed in the mid's and treble when early reports are about them being bright. How do you like them compared to the 650's? I have 6xx's (unmodded) and am debating what to do.
They're bright because of the uneven frequency reponse after 2kHz. There's a peak at ~4.5kHz and another at ~10kHz. But in between the frequency response drops too low and things sound kind of muffled as a result. The frequency response also has a rise after 10kHz which can add air but also tizz to things like cymbols and electronic percusion. Think of their sound as slightly V shaped but without midbass bloat.
Netherwind
So you think new pads would solve the problem? Or would it need to be EQ'd out? Once you start putting new pads on it and such the cost starts to get close to lower LCD-2 territory..
I'll see when I test some things out. The pads I'm betting will work well are $10.
Total: 13 (members: 0, guests: 13)
