Monoprice Monolith M1060 and M560 Planar Headphones
- Thread starter wordfool
Are there any IEMs out currently that have a similar sound signature to this headphone?
Nabooh
For those interested in replacing the ugly and flimsy headband:
https://fr.aliexpress.com/item/1005002189636045.html?spm=a2g0s.9042311.0.0.22336c37drMP5g ( choose the 105mm model)
Result:
Modded with:
-Fuzzor Mod
-Dekoni Pads
-3D printed grills
Because the two gimbals screws on each side seems hard to remove, I just unscrewed the top screw on both gimbals, and drill it a little bit bigger to use it on the new headband.
Result:
Modded with:
-Fuzzor Mod
-Dekoni Pads
-3D printed grills
MerroStep
- Jun 23, 2013
At the risk of sounding stupid, I had to replace the M1060 stock earpads because they finally broke down and peeled off. I started with placeholder pleather Brainwavz, they were serviceable, but bass sounded loose and treble painfully sharp.
I switched them to ZMF Eikons (lambskin). Bass feels tighter, soundstage feels narrower (wish it was wider), but the treble and sibilance is still painful. It's so bad I can't listen to these at normal levels anymore, they just hurt my ears and aggravate my tinnitus.
I'm at a loss on how to get the treble back to what they sounded like with the stock pads. And as an added bonus, a wider soundstage similar to the stock pads as well.
I can remember that I got some alcantara pads from https://vesperaudio.com/earpads?brand=181 back in the day. They build them as you wish and you have to write them via email but it was worth it. I ordered them as follows for the M1060:At the risk of sounding stupid, I had to replace the M1060 stock earpads because they finally broke down and peeled off. I started with placeholder pleather Brainwavz, they were serviceable, but bass sounded loose and treble painfully sharp.
I switched them to ZMF Eikons (lambskin). Bass feels tighter, soundstage feels narrower (wish it was wider), but the treble is still sharp. It's so bad I can't listen to these at normal levels anymore, they just hurt my ears and aggravate my tinnitus.
- Black alcantara
- Angled
- Memory foam
SomeTechNoob
- Nov 7, 2016
I think if you go back a few pages there's some discussion about leather pads from aliexpress. I actually ended up picking up a pair for whenever the stock pads wear out, but of course haven't had a need to use them yet.
edit: oops, it was the m1060c thread but I would assume similar characteristics https://www.head-fi.org/threads/mon...ones-impressions.869648/page-73#post-15696715
jotaku
zmf universal suedes are the closest thing to the original audeze microsuede pads that I have found. Way more comfortable than stock. No loss of soundstage.At the risk of sounding stupid, I had to replace the M1060 stock earpads because they finally broke down and peeled off. I started with placeholder pleather Brainwavz, they were serviceable, but bass sounded loose and treble painfully sharp.
Did they come with the rods as shown by default, or the hideous metal things from the product image? Is there a specific request necessary besides choosing the 105mm size.For those interested in replacing the ugly and flimsy headband:
Result:
Modded with:
-Fuzzor Mod
-Dekoni Pads
-3D printed grills
Matthew Willims
- Jun 28, 2016
So.... Does anyone know the trick to removing the headband from M1060/M1060C headphones? I'd like to install a Soundman headband so the can's don't flip when handling.
tlink
- Jan 17, 2016
I've arrived at this EQ profile. Using a dragonfly as DAC and a Topping L30 for plenty of power and loving them! Once you have gobs of power on hand the bass comes alive beautifully, and the bass transients stop sacrificing the rest of the signal.
studentism
- Jun 24, 2004
sorry to necro this, but just in case anyone else is searching this like i was: they're M2x6. also don't go to Home Depot or Lowes expecting to find them, go to AceHey anyone know the screw size/type for the grills? Lost a screw or two when trying one of the mods
Total: 6 (members: 0, guests: 6)
