Paper towel outside still looks the best. IME, you want a nice downward sloping response, not a boosted bass and rising treble. I might try some other mods but I'm so damn happy with my initial results that it might be better left alone.
Monoprice Monolith M1060 and M560 Planar Headphones
- Thread starter wordfool
Spiral Out
- Dec 31, 2013
I have the 7XX, and the M1060 is clearly superior.
I have the K7XX also and agree with you. The stock M1060 is way better. There is no comparison. I'm pretty sure sure I am going to sell my K7XX soon. I am not listening to them at all now.
Spinny
- Mar 13, 2017
Interesting results. If I read this right, the paper inside may well be the way to go.
I am not quite sure how well the graphs correlate with my hearing... but that curve looks like less midbass emphasis and maybe smoother top end..
Nothing but towel... maybe not as nice... YES?
Try all available options and go with whatever sounds best to your ears. It's all free to try and completely reversible. Simple as that.
amature101
- Sep 23, 2012
Hi, i saw that some of you are talking about some pad mod. Can some one direct me to the post on how to do the pad mod and what is the benefit of doing the pad mod?
I also noticed that 1060s seem to sound similar to audeze lcd-x expect that lcd x seem to be more smooth and cold. Is there anyway to mod 1060 to sound more cold and smooth?
Thank you.
Thank you.
mrkingdomhearts
- May 20, 2012
Anyone still listen to the m560? Really want to know how it does compared to the m1060.
Thank you.
This is as close to reference I can make them, unless I decide to do irreversible hardware mods...
Results of current config:
Audeze Vegan pads:
3 inch or 7mm paper towel circle placed under the grill but on top of the foam outside. You can try a black napkin if it suits your tastes better:
Red Trace is stock M1060, Green trace is M1060 with Audeze vegan pads and 3 inch paper towel:
I know there haven't been impressions on it but people I trust say it's kind of **** in comparison. It's worth it to save up for the M1060 and Audeze pads. It's like an LCD series headphone for half price with a 5 year warranty.
mrkingdomhearts
- May 20, 2012
LCD leather pads good or should I go vegan?I know there haven't been impressions on it but people I trust say it's kind of **** in comparison. It's worth it to save up for the M1060 and Audeze pads. It's like an LCD series headphone for half price with a 5 year warranty.
Look above for pics. The Leather Free micro suede pads.
Buy them from here:
https://www.adorama.com/aulcdeplfbl.html
or here since they're out of stock at Adorama:
https://www.bhphotovideo.com/c/product/1116989-REG/audeze_1002097_lcd_ep_lf_bl_black_leather_free_earpad.html
Buy them from here:
You need to use Vegan as we're trying to avoid internal reflections like the stock pads.
mrkingdomhearts
- May 20, 2012
How do you guys get rid of the glue for the pad change?
And internal reflections? What does that do exactly.(not in the mood to search through the whole thread)
You can use the glue to attach the Audeze pads if they don't come with double sided adhesive. What I'm saying is stock pads are leather, which is reflective. Changing the pads to micro suede or cloth helps eliminate reflections which will cause peaks and dips in the frequency response. You said you wanted warmer and smoother, the pad change will do that. I personally also added the paper towel on the outside to bring back some treble as it was lacking for my tastes.
Lorspeaker
- Nov 29, 2010
late to this thread
Hippocamp
- Apr 13, 2006
So, there should be no problem switching back to the stock pads if someone doesn't like the change? That is, does removing the stock pads or the vegan pads cause any damage to the pads themselves? Might have to try it if it is easily reversible (obviously, the paper towel is easily reversible, just worrying about the pads)...
Pahani
No, it should be completely reversible if you're gentle while removing the pads.I was not as careful as I should have been and the cloth backing of the stock pads came off. Partly my fault, because I was confused if it was supposed to remain on the driver, or on the pad. It should stay with the pad.
The leather-free Audeze pads should come with a ring of adhesive.......but even if not, the stock adhesive stays on the M1060 driver after stock pad removal, and you just smush the Audeze pads on in their place.
Badda bing, badda boom. Done.
Total: 14 (members: 0, guests: 14)
