Originally Posted by jpelg /img/forum/go_quote.gif
[size=xx-small]Two questions:[/size]
1. How do you all keep the plastic pieces from dropping inside the enclosed driver area?
2. Has anyone successfully removed (and re-installed) the plastic piece covering the driver?
TIA.
1. Use a clean-grooved drill bit with slow speeds, or a crown bit on high speed and use an air vacuum tool if you've got one.
EDIT
these are the kind of bits I'm talking about, dentist bits
EDIT2. But no matter how careful you are with the drilling, some tiny chips of material can fall in the enclosure, after each drilled hole, you should spend a good while tapping the driver-chassis/enclosure, while holding it both vertically and horizontally, to get the chips out. Blow some air into it, and continue tapping. If nothing has come out in a minute of tapping, you're good
The whole build is so rugged that it can take the tapping, I'm sure of this. The wires of course need to be handled with care. I have managed to open the cans several times, drilled holes into the enclosure, poked around and given the whole thing a few minutes of tapping several times, nothing has broken, nothing has come loose or apart. So this mod is really easy to do, if you can keep a dremel in your hand and can handle your heaphones with care.
2. Not yet, but I'm tempted to. Since this is a fresh mod, it should be explored what the driver enclosure holds within
Though it seems that the driver's edge is glued too, you can see the transparent plastic ring within the enclosure's seam. It would probably destroy the driver if you'd saw that enclosure off ..or maybe not, but I'm not going to take the risk right now
Plus as you inquired, re-installation is probably an issue too, it needs to be cleaned of all the glue and then glued back on with new glue, a ton of work I presume.
EDIT
I opened the cans again to poke around, and noticed these rubber plugs at the top of the closed cans, maybe they're for some feature in the PXC 350-450 cans? I took them off but I don't really know if that affects the sound, when you wear the cans they get pressed shut by the hinge.
the rubber thingy, see the removed one in the background
now both removed, they leave a 3x5mm roundish hole, but what for?
there you can see the hole from the outside when the can is put together again
3. Hero's Mod it is then
