actorlife
Yeah I am patient bring them on when you're ready MizMoxie !
Speaking of headphones, now I know 90% of headphones will benifit from the Zo, but is there a pair that stands out from the rest and have a excellent synergy . I would assume during the r&d phaze, Digizoid would of tested many sets of headphones. I know it's very subjective, but MizMoxie care to comment on what pair of IEMs, headphones or anyones for that matter that the Zo v2 truely benifits from ?
I had VERY high expectations for the ER4S, having heard all the buzz behind it offering the best detail retrieval among universals. As analytical as it sounds, I imagined the ER4S to sound thin, and lack bass body/impact. Whenever I'm faced with that combination, I can't help but scream out in joy because, simply put, I know my Zo, and my Zo knows me. Just as was the case with the RE252's, which are also on the analytical end of course, the Zo NEVER ceases to impress me. I'm hearing all the nuances, and all the while, the notes are thicker, and the bass body & impact is just out of this world! Even at max setting, there's just no loss of SQ whatsoever! This is the ER4S we're speaking of! Believe it.
Suffice to say, I cannot WAIT to see where the Zo V2 takes my ER4S, and whether or not it's a marked improvement, it makes little to no difference, really. I'll always have the original Zo to fall back on, if need be. No exaggeration, but if the original Zo was still available, I'd order a second to keep as a spare. God forbid if ever I have to send my current Zo in for repair; I don't know how I'd manage without it. Nevertheless, I have just as high hopes for the V2, and my credit card is practically glued to my fingers, until the little devil gets released.
Hats off to Digizoid for giving my entire music collection a whole new meaning. In my most humble opinion, the Zo is the best DAM.N purchase I ever made through Head-Fi, period!
Personally, I frown a bit when companies make claims that go completely against the laws of physics. If an audio device's driver is incapable of physically outputting low sub-bass, then there's nothing you can do about it, period. You can boost all you want but the driver's physical limitation will prevent it from being able to output those rolled off low frequencies. What products like zo does it simply boost/enhance frequencies that are not quite low enough so that most audio devices can still output those frequencies, but what you'll be hearing will NOT be what the music should sound like, because the frequency range that is being boosted was never supposed to be boosted in the musical material--if they were, the mastering engineers would have mastered them that way to begin with.
Instead of using presets, it's far better to use a parametric EQ and actually dial in a contour that actually fits the specific headphone/speaker you are using. So let's say if your headphones start to roll off after 40Hz, and sounds a bit anemic in the 80Hz range, then you surgically dial in two separate parametric bands that specifically fill those holes. You don't just use a broadband curve that boosts the entire bass region, unless you just couldn't care less if the music actually sounds anything like what the mastering engineer intended the recording to sound like. But this is assuming your headphone/speaker CAN reach that low in the first place. If they can't, then you're only adding coloration that's going to screw up all the hard work the mastering engineer did.
If you're using products like zo on small multimedia speakers that have tiny drivers, there's only so much it can do because a 2" or 3" driver will not be able to output low frequencies past a certain point. Boosting frequency ranges within its physical limitation only makes it very colored and you're still not getting those missing low frequencies, which then makes the whole thing even less neutral/balanced. The mastering engineers who made those recordings you're listening to would have veins on their foreheads exploded when they see/hear you doing that to the music they painstakingly created using decades of hard-won professional expertise.
IMO, it's better to use that money to actually first get a pair of headphones that can output low enough frequency ranges, and then use a parametric EQ and dial in the ideal sonic signature for that specific headphone. For people who are using portable players that have parametric EQ's (for example, the "Equalizer" app on the iPhone/Touch/iPad), you'll save a lot of money because an app like that will do wonders for you and it costs only $2.99. If you're using the computer as a source, then that's even less excuse to throw away $100 on a gadget like zo because parametric EQ's can be had for free on the computer by using excellent professional quality VST plugins that don't cost a dime.
But if none of the stuff I've mentioned is a concern, and you just want to having someone else try to fix your very specific and idiosyncratic problem with a broad and imprecise solution, then I guess the zo is worth the price.
They do need to hire a better marketing/webmaster person though. They can't even spell "you're" properly in their own advertising copy.
The amount of hyperbole in this thread is getting to astronomical levels, all aboard the FOTM train!
I've been following this thread since the beginning, and have valued your input. But I have noticed you stopped replying? What are you thoughts on the device now that many credible reviews are out?
do you own or have ever heard the ZO? than so the hyperbole of your hyperbole is the only hyperbole here my friend, and yours is the only train to this thread of which you will find no one getting on, other than your case, lol, what FOTM, in the end you will come to see the ZO of it all, or be stuborn and deprive your brain of pure joy, and continually to blow your ears while all of the rest of us enjoy blowing our minds!, oh and what color are the clouds in the world that you live in? just curious, mine are blue, and hey is that captain crunch I see, lol, and there's big bird, and I see a ship, wonderful simply wonderful sunny days!
