Hi Armaegis,
Arising from a discussion of using the XP8000/18000 as "clean" power sources over at AMB, from the man himself...
Anyone have comments on this?
I really don't know how the XPAL power packs end up with three different output jacks - 5V, 12V, and 19V - but the XP8000 sounds great with the Stepdance! No hum, buzzing, hiss, or anything else undesireable. The noise floor is wonderfully black (with a good source, or no source signal at all).
I'm just conjecturing, but I think it would be much less expensive a design to just tap multiple cells in different combinations of serial or parrallel circuits to come up with the three different output voltages. That, in combination with some diodes to control current flow, would be less expensive than a design that uses DC-to-DC convertors. (Just guessing.)
In any case, I don't hear anything unsavory when using the XP8000 with the Stepdance and LCD-2s. Ianmedium, Racio, and cukis350 have not complained of any noise problems either (at least when powering the Stepdance from the 12-Volt jack of their XP8000s). YMMV
Thanks for sharing that info, though. We're all experimenting here, so we really should keep our eyes and ears open for problems.
Speaking of which: If anyone decides to power their Stepdance at 15-Volts, please understand that I can accept no liability for any negative consequences, but I will gladly accept at least partial credit for positive experiences associated with 15-Volt operation!
Use a voltmeter to measure the power you are supplying to the Stepdance (tip positive, < or = 15VDC) before you connect it and proceed at your own risk.
Mike
