Who knows what the implications of their madness might be. They go back and forth between "electromagnetic radiation" and "radiation" on their site and it is claimed to magically eliminate or reduce such things within a 35 degree cone.
It should at least stop gammas which are the hardest to shield against anyway.
Maybe someone should call them up and inquire about using one for X-ray shielding. If one of them has the presence of mind to tell you that it won't work be sure to remind them that X-rays are EMR too. If they tell you that they're too high energy then ask them what tests they've done to determine that. While you're at it, ask them how they measured that 35 degree angle and if they've measured the rate that its effectiveness drops off with distance. Is it linear, inverse square, inverse cube, or something else completely?
Also, if I fire a single 20 MeV photon at a 90 angle to a series of Blackbodies placed 1 meter from the beam how many Blackbodies will I need to reduce its energy by half?
