Lorspeaker
- Nov 29, 2010
Bass is still a too much, but the other freq seem great... Treble might be too recessed though I'm not too sure.
Right now I'm messingn with Ryan (modulor)'s idea of putting tape over the hole and using a pin to widen it little by little. Works OK.What's your current config again?
(2)
Left Earcup: that wire was shorter inside this pair than in the previous set I opened up. Had to be very careful. Had to rotate the chrome plate/perforated grill coupling to be able to get them out of the way and stand them up on edge without unduly stressing that wire.
[Will try to post pictures later.]
Soundstage is more voluminous and 3-dimensional.
Bass is fuller and warmer, not bloated [but could stand to be just a shade more taut].
Midrange is more developed; vocals are chestier/throatier.
Treble is more open and better differentuated, e.g. with massed strings [but could stand to be just a tad more transparent] .
Textures, overall--treble, midrange and bass--are more dense, with a better sense of both macro- and micro-dynamics.
Tones are sweeter, rounder and fuller, adding a further layer of differentiability to instruments/vocals.
Localization in space of various instruments/performers is more pinpoint.
I will say that I think there is a slight trade-off in absolute transparency with either of the mods I have tried so far [Lors' MIKROSHEARTHRUBASS and this one--still in progress]. Some of that gossamer/spiderweb-like connectivity is lost [a plus for the stock configuration]. But the significant gains, I think, come about in added bass warmth and heft, improved tonal density/truer timbre, improved sense of dynamics and a larger, more open and more cleanly differentiated soundstage.
After reading the last string of posts between Lors, Wayne and Nim, I may make the following adjustments:
(a) replace faux-chamois with real chamois or deerskin [soft-side up]
(b) put fiberloft or very open/transparent acoustic fabric directly over the Rabbit Hole
(c) maybe introduce incrementally small amounts of Tacky here and there.
Also, have been auditioning with the Auvio cable, which is comparatively bright alongside the ET-4 or the Teds custon UPOCC silver. So I will have to do some more auditioning using other cables together with the latest mods.
+1This modding thing sucks. Once you've started, it's hard to stop. Becomes obsessive. They sound awesome right now, so why am I resisting the urge to open them up again??? Who's idea was this in the first place? Damn you Maxx134!
Honestly my problem is making the drivers match. It seems whenever I get one freq right, the bass or treble or mids aren't matched up.
Huh, that's interesting. I had extreme mismatch after I took off the cover holes.... waaayyyy more bass in the left driver. The right driver has something in it that you can see, but from what I could tell my left driver didn't, so I figured that I somehow removed the stuff from the left driver and that was causing the imbalance. My theory goes askew though because Lors's picture of his left driver also shows nothing in it. So I don't know what's going on. All I know is that the imbalance was there, and I had to do this to get it
