- Mar 20, 2010
The X1 sounds like a perfect fit then. I highly doubt you'll be disappointed.
Too much hype. Oppo hasn't proved anything yet with headphones.
Haha ok ethan
And thanks MLE, I'll buy one of those. Thanks for all your help.
How does this look? : http://www.amazon.co.uk/Pure-Shielded-3-5mm-Stereo-Cable/dp/B003PTZKDA/ref=sr_1_3?ie=UTF8&qid=1382375299&sr=8-3&keywords=3.5mm+to+3.5mm+cable
I dunno, it looks a bit too fat to sit right on the X1's cable jack. Try and get one with a piece that sits between the barrel and where the actual piece that goes inside the jack...
http://www.amazon.com/Mediabridge-3-5mm-Stereo-Audio-Cable/dp/B004LTEUDO/ref=sr_1_1?ie=UTF8&qid=1382377430&sr=8-1&keywords=mediabridge+cable+3.5mm
See?
Most onboard sound cards are pretty bad. One of the best decisions I made when I started getting into headphones, was buying an Asus xonar stx.
You dont need to spend that much, but there are some really good options around $50.
Can you give me a few name's? I checked the Asus xonar stx and it's too steep for my blood sadly.
Xonar DG or DGX. You could also pick up a used X-fi Titanium.
