regal
- May 27, 2006
You gave up the ideas of changing the output stage?
I installed the SC pulse transformer per the AES paper here:
http://www.scientificonversion.com/AES1998.pdf
Just wonder if anyone else can confirm if the mod hiface is already HIFI. meaning how does it compare to the highend transport like belt drive, cdm1, cdmpro , etc.
Would it make sense to try BNC attenuator on an RCA hiFace/DAC? (with RCA-BNC converters). It would work the same way, decreasing the output level, no? Impedance, well, be damned!...
It's a $30 experiment, why not do it & let us know? You can always sell the attenuators & converter if it fails.
I thought it was a $15 experiment, the one I bought was only $15 from minicicuits, did I get the wrong one? It was the 9dB version.
Where did you get this 9dB version?
The only versions I see are: 3-6-10-15-20dB http://www.minicircuits.com/products/attenuators_coax_fixed.html
You have to pick the ones that are at the bottom of the page.
[size=small]Attenuators, Coaxial (BNC)[/size] • Precision 75 Ohm • 0.5 Watt • 3 to 20 dB, DC to 2000 MHz
