Hello everyone.
Im trying to get my realiser working with my new pc equipped with nvidia geforce titan x.
Setup:
PC GFX HDMI output -> Realiser HDMI Input
I couldnt get windows 10 PC to detect realiser as surround device. it only shows as stereo with 2 channel.
Please help me fix this problem
What do you have set when you right-click on the speaker in System Tray, and select Playback Devices from the popup menu?
Once you have selected the HDMI output of your graphics card as the playback device and set it to default, you need to push both (a) Properties and (b) Configure to enable multi-channel formats. Now of course even if you send multi-channel output via HDMI, it's almost certainly going to be bitstream and still encoded, since this arrangement is designed to feed an AVR still-encoded digital audio via HDMI for external decoding there. It is essentially impossible to get the PC to do the encoding and send digital audio out via LPCM over HDMI, at least with standard Windows and with any software that I know of.
Remember the Realiser does not have its own decoding capability. It must be fed digital audio vial HDMI in already-decoded multi-channel LPCM format, with the expectation that the upstream source device/AVR has done the decoding and is delivering the now-decoded multi-channel digital audio via LPCM. My own experience is that the Oppo 10x players (with two external HDMI inputs and two HDMI outputs) are the only devices that actually provide that capability, using either DVD/Bluray disc-based source or external HDMI source input to the 10x via HDMI (e.g. from your cable DVR's HDMI output, going to the Oppo's HDMI input for feeding video to your AVR/HDTV and decoded digital multi-channel LPCM audio to the Realiser) are the only devices capable of feeding the Realiser via HDMI. I use an Oppo BDP-103 in my own HDMI Realiser setup for exactly this reason, along with a Yamaha RX-V867 AVR. HDTV video is fed from the Yamaha AVR (fed from the one of the Oppo's HDMI outputs) and the Realiser is fed HDMI multi-channel LPCM directly from the Oppo's second HDMI output.
For my PC setup (where no decoding to LPCM is possible within Windows or any player software that I know of) I use a different setup. This makes use of an earlier generation Yamaha RX-V863 AVR and my serial #0001 Realiser which has no HDMI input but which only supports already-decoded 8-channel RCA analog analog input. I do not want to route HDMI output from my PC to the AVR, because that feeds video back to my second monitor which will be 1920x1080 and I want 1920x1200 on that monitor. So instead I route optical output from my PC (which has an optical S/PDIF output for digital audio) to the AVR. This is after selecting the optical output in Playback Devices to default, and configuring Properties and Configure to support all multi-channel formats. Video to the second monitor remains standard, supported by a standard DVI cable from graphics card to the monitor. It's only the digital audio that I've separated, and bitstreamed out of the optical connection to the AVR where it will then be decoded.
The AVR has 8-channel RCA analog "preamp outputs", designed for feeding an external amp/speaker system (although the AVR obviously has its own amps which can feed the multi-speaker sound system). I send these already-decoded multi-channel analog "preamp outputs" from the AVR to the 8-channel analog inputs of the Realiser. I have an old Stax SRM-T1S/Omega-1 headphone system connected to this old Realiser and old Yamaha AVR, for listening.
Note that optical connections do not support 7.1, but only support 5.1. However what I'm listening to from my PC through this external audio equipment is Windows Media Center recorded HDTV, as this PC is my HTPC. Since HDTV only delivers DD 5.1 audio, the optical arrangement from PC to the AVR is not really a limitation at all. So I don't really need DD7.1 audio from this particular Realiser. Yes, I do have a BluRay drive in this machine and do have CyberLink PowerDVD on the machine if I wanted to play a BluRay movie (which I never do) with 7.1 audio possible. But I simply can't choose the True-HD MA or other 5.1/7.1 lossless formats, since optical also does not support lossless formats nor does it support 7.1. But then I never actually watch a BluRay movie on my PC this way. I go to my "main equipment" based on Oppo 103 and Panny 65VT50 and Yamaha RX-V867 and HDMI Realiser feeding Audio-GD NFB9 DAC optically, which feeds my Stax SRM-007tii amp via XLR which feeds my Stax SRM-SR-009 headphones.
Anyway, I don't know what software you are planning on using on your Win10 machine, but you cannot just feed still-encoded multi-channel bitstream digital audio via HDMI to the Realiser. You have to feed already-decoded multi-channel LPCM digital audio to the Realiser via HDMI.
