Walderstorn
- Mar 25, 2015
Great post m8
Just got my FXT200LTD yesterday from amazon for $125.
This is my first impression:
I think if you already owned some high end IEM then this is not for you. I think overall it is OK but not that impressive.
I commute by metro bus. So first thing i notice is isolation not good. Cable noise is bad unless u wear it around the ear (yes, i did that and it fix the problem.).
Sound not that warm if compare to woodie. Sound stage also not that wide. A tad not that easy to drive the IEM, i have to up my volume 2 levels. Bass a little bit less (it is there but not that much) but more control. Sound especially female vocal is very clear (may be due to less of bass).
Build quality is excellent and very light weight. The gold color is pretty good looking and low profile (not like those yellowish gold).
Not sure will burn in change the sound signature or not. but will try it out.
Anyway, i think is it not bad but still it is just OK.
On the whole, I think you've provided the most informative (in terms of impressions) feedback on FXT200s. OTOH, I don't think it aspires to be an audiophile, or even a well-balanced sound reproduction.
It gives a somewhat contrived and selective, but very well defined, and for some attractive, spotlight on lower highs and upper lows. Contrary to what many have suggested, I think its a perfect pair to use on noisy trains and other areas with loud ambient noise. It doesn't cancel external noise but the exaggerated reproduction it provides helps to overcome the ambient noise in such environments. Sitting on a noisy commuter train, I'm unlikely to ever hear them anyway. At home, I have better things to listen to.
Its not suited to quiet classical solos such as with pianos. The ambient noise of keys being pressed or breathing tends to come out too much. Nor is it good for high register vocals. Too harsh. OTOH, its great for listening to grungy rock recorded in a boozy sweaty dive with a pint in a plastic glass and still-legal cigarette smoke filling the air. I love it.
Just want to report back to the thread after using it and burn in for a while.
You really need a good AMP to drive this IEM. Using ZX1, the bass is more noticeable compare to using my Z3 phone (yeah, big Sony fans, don't judge). I even try the tape mod, make the sound more warmer but not good for commute because with all the outside noise, it will sounds more muddy.
But overall still not really like the sound signature, i think it is too bright for me, sometimes i felt that it exactly sounds like BA (if i compare it with XBA-30 and H3, yes.. big Sony fans, guilty as charged). I think may be i got misguided, i always kind of thought dynamic driver should be more "livelier"? Captain please explain The sound is too bright for me, make my ears feel fatigue after listen for 1 hour.
Another thing, i am not sure you guys experience this or not, for some reason for same song with heavy bass if i use woodie, i felt fine, but using this IEM, after 10 minutes, i felt my ear drum a little bit pain. Tried couple of times and felt same way, I wonder what is causing that...?
Overall, the conclusion this IEM is just OK. But hey, this is just me, all ears are different
Last, just want to get some recommendation from all the experts here. I like the sound signature of the woodie. Is the IE80 or CKR10 has the same sound signature? All you guys know any other IEMs which sounds like woodie?
That's all, thanks for reading. The quest for best IEM hunt still continue....
