- Feb 23, 2011
I think your .zip files are corrupted or something; I can't open them with 7zip on Windows nor Mac unzippers.
My circuit board has no trouble sliding in or out of the aluminum enclosure's rails.
I just noticed a strange thing going on with my C5 today. This morning when I powered on my Cowon Z2 + C5 setup and hit play, I got silence for about 5-7 seconds, then static and noise started coming in at a gradually increasing volume until it hit the preset volume I left it at before powering down the night before (and left it charging overnight). I thought it was strange but didn't really give it any thought and chalked it up to a one time fluke. But when I turned it on again later in the morning, I got the same strange sound. So I did some testing throughout the day and it seems it's got to do with the bassboost. If I leave the C5 turned off long enough (not sure exactly how long yet) and turn it on when the bassboost enabled, I will get this strange sound. If I turned on the C5 with bassboost disabled, then it'll play music and the correct volume right away with no noise or distortion. It makes sense that it's related to bassboost since I only started using bassboost yesterday. I was able to record couple clips of the strange noise happening in 2 different instances using my phone and I'm attaching it here (rename to wav for playback). Did any of you out there experience something similar?
I do have to also point out that one of the traces on the PCB had it's soldermask scratched off due to being right under the rail that holds the PCB in place. The fit is real tight and I had to wiggle the PCB to get it out and I suspect that it got scratched off then. I emailed John and he said that as long as the anodizing is not scraped off it should work fine. And if the C5 does short due to metal-to-metal contact, it should just short out one channel and he will replace the enclosure. I'm attaching a pic of the scratched off area. Don't know if this has anything to do with the noise issue above though. Just a heads-up for those of you that are doing mod/dev work.
