- Feb 23, 2011
The C5 and C5D were built with earphones in mind, so I'm pretty sure the noise floor is sufficiently low enough for most earphones. XD
Whats the difference between C5 and C5D in the amp section? They are the same or C5D is better than C5 as an amplifier. Since C5 is made for earphones, that means it cant drive my sennheiser hd 25 (70 Ω impedance)? How the sound signature is different from pico slim?
The C5D is the C5 with a DAC. I believe the amps are the same. I also believe that the C5/C5D will work with high impedance headphones, depending on the sensitivity. The HD25 at 70 ohms doesn't even qualify as high impedance. I've used my C5D with both the HD700 at 150 ohms and the Westone W40 at 31 ohms. I have the volume low, but not all the way, with the W40. It does well with both at low gain.
Don't know anything about the pico, sorry.
Cool, thanks. I really do love the O2, but I want something with bass boost and a smaller housing. C5 it is!
Any one tried to pair this to an iPod classic 5.5g (not rockbox) and m100 cans? Any feedback?
Yup, well with the 5th gen, not 5.5. The line-out is kind of weird with the iPod 5th gen since you still adjust the iPod's volume, but it doesn't do anything.
Sorry for the low-quality photo. Low-lighting destroys the image quality with the iPhone. >.>
Nice! Thanks! Hmmm I don't get the volume adjusting part.. What do you mean by it and don't do anything? Does it bypass the iPod DAC too?
Yeah sorry, I wasn't clear on that. The iPod 5/5.5th gen both support line out, but for some reason you can still see the digital volume bar on the device (normally you can't adjust/see the digital volume). In Rockbox, the digital volume actually does change the volume level, but in the iPod operating system the volume changing doesn't do anything.
I don't believe there is any way to bypass the internal DAC of the iPod [Classic] series unless you buy an expensive (typically $500+ USD) "Apple certified" DAC unfortunately.
