f198
- Aug 30, 2013
Finally able to compare C5D, PHA-1 and O2.
Soundstage-wise O2 is a bit wider than PHA-1 but not much and in turn wider than C5D. C5D though appears to have more depth.
Detail resolution on the highs sounds the same for C5D and O2. PHA-1 is a little brighter.
The mids are clean on O2 and a bit more forward than C5D. PHA-1 tends to be sibilant and appears to have more focus on the mids.
PHA-1 is a bit punchy compared to O2. But O2 is a bit better in clarity and details. It is also tighter. Overall the difference is subtle in the bass.
C5D appears to be not on the same league as the other 2. Have less detail and a bit muddy. That is with the bass boost at the lowest level. Turning the bass boost on gives it more volume in the bass and quite nice and enjoyable especially for bass heavy tracks. It doesn't appear to bleed into the mids but still lacks the clarity compared to O2.
Thanks for the comparison. Which headphones were used ?
