ozkan
- Nov 1, 2012
You signed up for Hyperion + Delta, too @ozkan?
Nope, only for Hyperions but may change to Hyperion + Delta after reading H20Fidelity's reviews.
Hi Brooko,
I REALLY love your reviews, and your opinions are invaluable to me!
A quick question for you (my sincere apologies if I have missed it already being asked / answered):
I listen mostly to rock / alt. rock (Coldplay, Muse, etc), and going to receive my X3 2nd gen any day now. I do like bass that has some kick to it, but I am not a bass head. Just like it a little more bassy than 100% flat / neutral...
I am debating between the Hyperion and the Delta. Now, I know for a fact that even if I end up with the Delta - I will audition all 3 filters, choose 1 of the filters, and will never switch filters ever again.
I do NOT consider myself an audiophile by any mean, and I have not been tested for many years, but I seriously doubt my hearing is perfect...
So, having said all that, and I know it is very subjective - is it worth the very high price premium of the Delta compared to the Hyperion?
Would the difference in sound, for mere mortals with imperfect hearing, be worth paying 3x the price?
Looking forward to your answer, so I can place my KickStarter pledge
Keep up the excellent work of reviewing gear for us all
Zachi.
Hey @Brooko: Will Sony Hybrids fit on Hyperion and Delta? If so, is it a good match? I find the foam-filled Sony Hybrids make silicon tips fit much more securely in my ears than regular silicon tips. Sound good, too
Yep - Sony Isolation Hybrids fit both. The Delta is a really tight fit - you need to really force it, but once they are on, you're golden. They fit the Hyperion a lot better - slightly smaller diameter nozzle.
I get slight driver flex on insertion with the hybrids - but that's just because with my ears, I get such a good seal that it's hard to equalise pressure initially. I use Comply on both (personal pref) - but the Sonys would be my easy second choice.
Thanks @Brooko.
@hakushondaimao: I'll have to try the hybrids on my MA750 - can't get those things to stay in my ears for anything!
anyone could explain the differences between TDK BA200 vs Delta?
http://www.head-fi.org/t/584123/tdk-ba200-appreciation-thread
from the graph, are they similar? not really sure how to read these graphs. Tia.
Waiting for new filters from Bob (for the Techne) - then will update my review accordingly.
As far as the Delta goes - I still use it most days, pretty much rotate between the Delta, Titan and A83.
If anyone has any specific questions, we'd be more than willing to assist.
