audionewbi
- Jan 24, 2010
what program do you rip/convert your audio files? this way I can produce a guide for that particular program.Thanks for the tip but uhhh, English please?
I use XLD on a MacBook Pro. But instead of ripping directly from the CD (which I find is slower), I copy the CD onto my HD and convert from aiff to flac.
To complicate matters, I have one extra track that I bought from the iTunes store (stupid bonus track only available there) and would like to stick it in. It was easy with the AK240, with the Gapless option, but what an incredible pain to listen to stops/starts of an originally gapless album on the Paw and Tera.
Setup Preference
1)Open XLD->Preference
2)Click on output option and select "Allow to embed cuesheet", okay it and close
Add files
1)File->Open folder as disc: Navigate to the folder where the album files are
This should open a window where we can edit tag, add album art and etc
2)From the drop down menu select "Save as single file (+cue)
Done!
Audionewbi, I could kiss you! It's playing perfectly on my PG. Now, is there any way I do it for WAV so I can play it on the TERA? The WAV option on XLD does not have 'Allow to embed cue sheet'. Can I just convert the resultant flac to wav?
I'm having problem with transferring large ISO files to the SD card.
Using the Lotoo player it is only formatting the SD card to FAT32. I tried to re-format the SD card using PC to NTFS but Lotoo does not recognize it.
Can anyone help me on how to transfer larger files to FAT32?
Lol . I should really read the specs of products I review. Cheers!Well it says ISO supported
