- Mar 20, 2013
I have bought the following USB C to USB B cable:
https://www.amazon.co.uk/Cable-Matt...c+to+to+usb+b+3.0+cable+matters,aps,91&sr=8-1
This cable works fine connected directly from my z fold 3 to the Signature V2 but there is no USB OTG cable in between. Could you please advise on whether it is ok to use this type of cable?
Z Fold 3 ---> USB C to USB B Cable -----------------------------------------------> Zen DAC Signature V2
Or, would you recommend buying a USB OTG cable and using a USB B to USB A cable to go from the USB OTG cable to the Signature V2?
Z Fold 3 ------> USB OTG -> USB A to USB B Cable ------------------------------> Zen DAC Signature V2
Thank you so much for any advice
If that USB C to USB B cable works for you, it's perfectly fine. There's no need to add anything extra if the connection is stable. Hope this helps, thanks
Stay updated on iFi audio at their sponsor profile on Head-Fi.
