mannkind246
- Sep 15, 2013
In term of micro details, which one is more superior, Hugo or iDSD micro?
Hugo. Hands down.
Not by much. I have both, and can't tell the difference when I swap between them.
I prefer the Hugo as a home DAC plugged into my full size amp, but I prefer the ifi when travelling. It's also a lot cheaper, so if I damage it, or lose it, it can be easily and cheaply replaced compared to the Hugo.
If budget is an issue, then go for the ifi. I don't think you would lose sleep wondering if you should've gone for the Hugo instead.
I had both. They were on my desk for the duration of 6 months. Now I only keep the Hugo.
The difference while not huge, is significantly appreciable. Hugo's soundstaging while a little smaller compared to the iFi sounds more natural. The increase in dimensions of the soundstage out of the iFi appeared to be too artificial.
Then there is the bass texture of the Hugo. iFi couldn't touch that part - not even with a ten-foot pole. As to the rest, objectively speaking, it becomes a toss: hinging on personal preference.
Given the relative portability of the Hugo compared to the rectangular trapezoidal shape of the iFi, the former is just way more stacking-friendly.
Just my two cents.
May I know what kind of headphone did you use when comparing Hugo with Ifi Micro?
HD800, DT1350, DT770 32. HD600, AKG K3003. Noble 4c.
Could you say which was better with the HD800 when comparing the Hugo with the iFi?
Just my two cents.
Haha I thought so. My ears think the same I believe...
Pretty surprised about the soundstage thing. My friend's getting an iFi in the near future so he'll try to mock the Hugo for that I guess.
I prefer the Hugo acting purely as portable dac. If I add an amp to my stack... Then it becomes a whole different thing. It is in this kind of setup that the Hugo is superior to the rest of the portable dac.
Ever heard the Sony NWZ-F887 soft tweak to create that larger soundstage effect? It sounds so artificial. That was the same feel I got from the iFi.
I followed your posts about the HD800 + Hugo synergy on the Hugo thread elsewhere so I do get what you're talking about. I am yet to have tried an external amp though.
About the Sony player and the soundstage, I try to stay away from any Sony device/headphone. But yes I can guess what're you're saying but I'll know for sure once my friend gets it and I can compare versus my Hugo I guess. But I do love the crossover and the soundstaging of the Hugo because it's quite unique and musically involving. It makes it easier to listen to music for me.
One question I got in case you can talk about this over private messaging because this is off-topic: I am burning my Hugo in atm and I am around the 30-40 hour mark. While it has been a while since I demo-ed the Hugo at the store before getting mine, I feel like at times that the soundstage is smaller than it was (slightly) and that it is getting bigger and bigger as it's becoming burned in. Can you recall your memory back to when you got yours and say if you had the same experience as mine or not? It might be my brain adjusting of course but you never can know for sure.
Thank you.
Could be placebo sir.
There are only two distinct sounds I've heard from about 7 different Hugos I've auditioned in the last 9 months.
The Hugo with the old firmware that does not connect with an Android mobile phone and the new ones which can act as a plug and play dac to an Android phone.
The old one has a larger soundstage.
