kenshinhimura
- Jan 16, 2013
im thinking that as well... wonder how a 5LE with jerg pads would sound
sound great on my he5le.
Since everyone is posting their EQs lately, I thought I would post my latest:
I have a little 'bass boost' in the 50hz region, a light cut to the 1 khz region, and another boost around 4 khz. I actually cut treble from 7khz - 20khz. Everything is quite subtle, but I have noticed I really like having a 3 db boost or so in the 50hz region - gives the bass a tad more weight without it getting too sloppy or boomy.
Indeed I have boost of about 3db at 50k my self
but HOW DO YOU ppl get Easy Q working in FooBar! I can't get it to work... :/
that said I also have a nice boost to upper mids as well but I also dip the 7-10k area while brining 14-20k back to neutral
It wasn't that straightforward for me either. I'll try to remember what I did. You really need to do two basic things: Get a VST wrapper for Foobar, and then Get Easy-Q.
*download "George Yohng's VST Wrapper" for foobar. Install.
*Download Easy-Q
*Add Easy-Q .dll file to the foobar/components directory.
*Load up Foobar -> File / Preferences / Playback / DSP Manager
*Add VST Wrapper to the list of Active DSPs
*Possibly close / restart Foobar
*VST Wrapper is now running in the taskbar as an icon or a hidden icon (use the small up arrow)
*Right click on the icon, select "Use VST Effect / EasyQ"
*Play with EQ for hours, save the ones you like.
Once setup, VST and Easy Q should pop up with Foobar every time. You can follow this same process but use Electri-Q if you wanted to. Both programs need a VST wrapper of some kind. Personally, Easy-Q was better for me. But I hate that it doesn't sit within the foobar player, and I always have to minimize everything I am doing / re-select Foobar to see it and use it again. Sometime I ought to go back to back with the 31-band EQ built into Foobar to see if all the extra setup is REALLY worth it.
I like the alternative VST-DSP adapter more:
http://wiki.hydrogenaudio.org/index.php?title=Foobar2000:Components/VST_adapter
Let's start voting on HE-400 pads (pleathers vs. velours). I prefer the stock pleathers.
Pleathers: +1
Velours:
I "prefer" Beyer velour only from a comfort/aesthetic standpoint, but I know from all that has been said and graph evidence that the Jerg pads bring out the absolute best in 400s. So I will be switching soon.
How about the choice of 1) stock pleathers 2) stock velours 3) jerg pads 4 ) any other pad ? !
