HiBy FC6--R2R dongle DAC reborn
Nov 26, 2023 at 9:51 PM Post #61 of 245
Just to make sure that I understand correctly:
FC1, FC3: in-line microphone yes, in-line control no.
FC4, FC6, FD1, FD3: in-line microphone no, in-line control yes.
That's right
Nov 27, 2023 at 1:49 AM Post #62 of 245
Nov 28, 2023 at 4:22 PM Post #63 of 245
So, just used dfu tool to upgrade to 1.07, seemed successful and seemed to verify that it's 1.07 now, but Darwin filter is not an option. I see minimum phase, slow and fast options in filter section, but no Darwin.
Nov 28, 2023 at 7:48 PM Post #66 of 245
Can you quote the link you downloaded from?
Nov 29, 2023 at 8:23 PM Post #68 of 245
Dec 1, 2023 at 1:01 AM Post #71 of 245
One thing i have seen once i got the fc6, with firmware version 1.02 I could hear a difference when moving amongst all the filters, now after 1.07 I don't hear that, not sure if there is no difference at all or I am doing something wrong.
Dec 1, 2023 at 2:11 PM Post #72 of 245
Did you use the DFU tool to update to the file provided in the package, or did you search online using the tool? Because this update hasn't been uploaded to the cloud yet.
I used the file in the package, clicked open and chose it. And yes, I rebooted as well. When I clicked check it said 1.07 version.
Ok, decided to try the flashtool and it seems to have worked correctly this time. I have Darwin Ultra now!
Dec 2, 2023 at 12:14 AM Post #73 of 245
what about Darwin Ultra vs everything else? Also, what sample rate are you at?
