mwilson
Ants in my Stax
- Dec 28, 2009
Wehell what do we have here? Welcome back googleli!
The three shelves on the frame of this audio rack I'm having done are welded using 1-1/4" angled steel then the granite will slot in. For double insurance against vibration, aswell as the antivibration dampers I'll also try rubber 1-1/4" wide + 16th" thick around the horizontal part of this angled steel. These antivibration dampers I'm getting will only be for the BHSE + Aristaeus spiked feet, my source I have and the power purifier I'm getting have rubber at the bottom of their feet.
Justin, I am number 44 and still have not got any notification for the payment of balance, may I know when I will get it? An estimate will be fine. Thanks.
Stay updated on HeadAmp at their sponsor profile on Head-Fi.
At the level of your headphone gear which will be same as mine, namely the Esoteric K01 and BHSE, I would at least use Solidsteel or TAOC racks and TAOC or Linn plates for the spikes, if not some Finite Elemente racks or Cerabases as feet replacement.
Hi Dave,
To be honest I'd sooner have similar kind of wood used on kitchen tops but I thought Granite would be the best to use. Would wood be a better material to use, if not then what ?
Dave.
P.S. Thank you for letting me know this Dave because Granite in the UK is quite expensive, just like most things.
hi Dave, there are various synthetic stone products, which are often used in kitchens, but also some are used in audio applications. these materials tend to be considerably more inert than natural granite, and they can be aesthetically pleasing too. i'd be more inclined to use these type of products, or even various wood materials as many speaker cabinets are made of such materials and can be handsomely dressed up, possibly with veneer. anything form butcher block to various composites would do nicely. i think all would be functionally superior to granite.
Why not go with actual isolators instead of couplers that are erroneously called isolators?
http://aurios.net/products/pro-max-bearing
se
Looking nice Justin. Out of curiosity (and pardon my noobness in this), your burn-in is just having it powered on? I noticed that you're not having any source/transport plugged in, nor headphones, etc.
se
