Hi guys. What size comply tips fit the B3s? Looking to get some since the foams that come with them are getting a bit rough and gross now.
The 400s fit nicely.
I´ll buy a Havi B3 Pro 1 for my Fiio X1.
Is the X1 strong enough to driving the B3 without issue or need it an additional earphones amp.
Thanks.
Short answer is yes, but the Havi B3 Pro 1 will benefit with something more dynamic with a better amp section.
Thanks for answer.
So if I right understand, the B3 will not play with his optimum sound without an amp on Fiio X1.
Is it that what you mean?
Correct. I own the X1 and it is the item I use the least because of it's weak amp section and personally I think the sound is way too soft/smooth for my liking. I'd recommend the xDuoo X2 if you're on a budget.
Although the X1 might have enough power to get the Havi loud enough for you, looking into the Brainwavz M3, MeElectronics A151 or even the cheap UE200 is something you could consider.
Because of your Post I have ordered a Havi B3 Pro1 and hope he in the X1 satisfyingly functions.
Press all thumbs.
Thanks for answer.
If it's any consolation, I ran mine from an iPod Touch most of the time and it still performed admirably.
Yep it's more of a good/ better comparison than a bad/good thing.
