Well They just arrived at noonish. Boy do these SUCK.
Juice that is..... Tried them out of the box with the Large red-cores installed, my initial thoughts were: Hey these are pretty good. Cranked up the Volume noticed that, yes, you do have to turn these up further than most but Oh my. You guys lied about the Bass. There is PLENTY. Maybe not like the Senns or Titans but it's there when called for. Mids, Treble were Crystal Clear. Put on a Mix of Big Room and Progressive Trance music and Hit the 6 DB boost on the E12. Yep. We have a winner.
Okay so I was rolling tips while I listened. I tried all the ones provided, the Red Cores definitely sounded best of the included tips to me. BUT I also had a set of my trusty Auvios from Radio Shack. These put the Havis in a different building. Everything became very tight and defined, awesome Bass response. It seems the Auvio tips are becoming my goto's for over ear IEMs. In case you aren't familiar with them they are similar to Sony Hybrids but with a slight bullet Shape-ish, Large color coded Core and a more substantial, (Heavier), Silicone Material. Kind of a Sony Hybrid on Steroids. You REALLY should try them out.
Now it's off to the Station for 200 Hours to let my "Ears" adjust to them.
I will rave about them in a week or so....
TWIN
