Good morning !
here the pic
I would not mess with the unit after all. Maybe
i would have preferred to see used a transformer of this type here
or this one here
if i am not wrong
this types have primary and secondary windings separated.
Usually this results in a better rejection of mains noise ! this is fundamental with digital i suppose
But googling i see that toroidals are very fashionable these days ... actually the look really nice
But they also sound nice ?
They are instead the normal choice for power amps for instance.
Almost no one uses big and heavy EI transformer these days.
Personally i like more EI trasformer also for amps. It seems that they usually give a better bass ?
Regarding tubes i guess you are right.
For line stages i have a predilection for the
powerful tubes usually used as drivers for the output stages in many tube power amps.
For instance nobody cares of the
12bh7 ... for me this tube would be exceptional as line stage (even if no one is using it).
I am sure as you say that tube selection is the 1st step and very fundamental
i see almost everywhere ecc82 ... too weak tube for me.
The 12bh7 (or similar) correctly used could give exceptional sound ... clean, powerful, transparent ... everything.
One day maybe i will buy a kit from ebay adaptable to this wonderful tube.
Thanks again and kind regards, gino
